No problem
Its just A must to tell or give A reaction.
Its always fine when you now the problem whe learn off it.
End when sombody got that kind off problem that we help.
Regards
John.
Thanks for letting us know your cure for problem
I still need more info
Model#
serial#
Have you checked the electric soloniods? F/R
Are you ckecking pressure at correct port.
E mail at work pacfork at telus dot net
No I check it
I did the measerments no pressure
I want to take open the transmission
There I need the info for
Kindly regards
John.
Hi I Need more info.
I have sent you a Email?
Is the inching valve stuck open?
Jeff
