hydrostaic trouble
Got an H30D in the shop with17000 hrs, its a 351J06076230 ser#. The problem is when moving in either forward or reverse the machine seems to lurch as if the brakes are dragging or there is a problem with the pump. it is has the 2 pedal system one for forward and one for reverse. We've tried pressure tests and come up with nothing. it seems to get worse as the oil gets up to temperature. their doesnt seem to be noise from pump cavitation and the oil doesn't look aerated. any suggestions wuold be great
  • Posted 14 Oct 2005 06:06
  • By greenbastard
  • joined 14 Oct'05 - 3 messages
  • Saskatchewan, Canada
Did you ever get it figured out?
  • Posted 9 Sep 2019 12:32
  • By matthew_doyle
  • joined 8 Sep'19 - 5 messages
  • Alberta, Canada
Matt
Having same problemn on several LP models with 15000 hrs. If you find something please post.
  • Posted 22 May 2015 12:15
  • By edward_m
  • joined 11 May'15 - 111 messages
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
