hydraulic problem
Hi sir,i have7 ton forklit details mentioned above i had changed the steering pump after that steering is not moving in low ideal only on little more eccelerator it moves,and even brake is less as this pump is for steering and brake please let me know the exat pump capacity i fixed the new pump rated 500 rpm 200 psi as there was no details on the old pump.Thanks Bye.
  • Posted 23 Mar 2015 03:41
  • By felix_d
  • joined 9 Jan'15 - 22 messages
  • UAE, United Arab Emirates
Steering relief should be set at 1700-1800 PSI.
  • Posted 24 Mar 2015 23:30
  • By BREWSKI
TCM FD115-3
Aichi RX07B
Libiao Robotics
