Hydraulic Interlock
Code 524285-4
The mast control valve was removed and rebuilt due to excessive internal leakage ( mast was drifting down ) After it was reinstalled, now upon star-up the forks will raise automatically from 1/2 to 3 inches every time. This code appears, no tilt or sideshift functions but will lift ok.Once the machine is restarted then all functions are back to normal.
The mini levers req recalibration ? if so can this be done with the on board computer and what would this consist of. Ser# of unit N005V01697D.
Hope someone has info on this subject
Thanks
  • Posted 29 Jun 2011 00:16
  • By BrewCrew
We`re here for a good time
Mini levers can be calibrated through the dash. But you will need to adjust the lift and lower proportional valves to stop the lift at start up
  • Posted 29 Jun 2011 07:23
  • By sean3
  • joined 14 May'11 - 46 messages
  • lancashire, United Kingdom
Michel Denis Michel Denis
