Hydraulic fluid type?
Forgive me for sounding ignorant.
I have a Yale GLC025 that is low on hydraulic fluid.
What type fluid should I put in?
Thanks, Robert
  • Posted 6 Sep 2021 05:02
  • By Robert_Merrill
  • joined 8 Dec'19 - 4 messages
I assume the truck has 32 weight hyd oil in it but the truck is and older model some one might have changed it over the years if you were thinking about changing the oil it depends on were the truck is being used you could use 46 weight in a warmer climate 46 is a little thicker make sure when checking the oil the mast is fully lowered or it could overflow when lowering hope this helps
  • Posted 8 Sep 2021 03:13
  • By Scott_
Scott
