Hydraulic Fluid Leak
Model S50 with a H or J behind it. Serial D2D. Chevrolet Engine.
Symptom: Bubbling hydraulic fluid out vent tube at high RPM's.
Fluid level is at minimum on stick, probably due to fluid bubbling out.
Changed filter.
Hope someone has had this problem and has a solution.
  • Posted 19 Apr 2011 06:30
  • Modified 19 Apr 2011 06:31 by poster
  • By rrlift
  • joined 27 Feb'09 - 22 messages
  • Illinois, United States
It sound as if air is being introduced into the hydraulic system and possibly causing a foaming effect..a worn pump can also create this condition.
  • Posted 13 May 2011 00:44
  • By ray_k
  • joined 1 Jul'10 - 39 messages
Sue Tomic Sue Tomic
