Hydraulic fluid leak from behind left drive wheel
I have a C5 with power brakes (wet brakes) that is leaking hydraulic fluid from behind the left front wheel. One tech stateed that he previously replaced the O-rings on the brake lines because they were blown out. Another tech thinks the brake housing/case could be cracked. And another tech stated that the axle could be leaking.
The truck leaks very slowly when sitting.
The truck leaks pretty bad when driving.
The brake pedal feels firm and consistent.
The brake housing doesn't appear to be leaking/cracked.
It seems to leak worse with the activation/deactivation of the parking brake.
I'm open to suggestions on what you folks may think the issue is before I start disassembly. I don't have any technical resources for this brand or model so any assistance would be greatly appreciated.
  • Posted 13 Oct 2025 22:17
  • By Kay_Coff
  • joined 13 Oct'25 - 2 messages
  • Michigan, United States
I tried to fix it!
Much appreciated! I had my parts department order the service manual and after disassembling the power brake housing, I found that one of the O-rings (same one as before) on the lower crossover tubes had been damaged.
  • Posted 17 Nov 2025 23:44
  • By Kay_Coff
I tried to fix it!
Crown sells a reman brake, that's your best bet. It takes a special socket and when reassembling I suggest gluing the oil seal in with pipe cement or you could be doing again. Jack up on side your changing, pull axle, remove big axle nut lock bolts then nut. Count how many threads you see on axle housing because your going to have to tighten back to that point, remove the two brake tubes on back. There are two bleeder screws, one for parking and one for service, get a plastic tube and bucket, cause it needs to be running to bleed and it will shoot oil everywhere. Not a bad job after you do three or four lol Good luck
  • Posted 15 Nov 2025 06:25
  • By Stoney
  • joined 15 Nov'25 - 3 messages
  • Fl/Ga, United States
Stoney
Aichi RX07B
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
Louisville, KY, United States
St. Louis, MO, United States
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
Aichi RX07B
USD1
June 9-11, 2026 - Stuttgart, Germany
