How to clear error codes on Mitsu LP
I have a Mitsubishi FGC25N that needed a new starter. Starter is replaced and the machine is working properly.
How can I clear the error code it is still displaying?
  • Posted 27 Feb 2013 23:02
  • Discussion started by MM0028
  • New Jersey, United States
Codes E-27. E-28
Done changed crank sensor need to no how to eras codes
  • Posted 10 May 2022 01:23
  • Reply by Thomas_Gilbert
  • Kentucky, United States
Thomas gilbert
what is the code being displayed?
and generally the pedal proceedure is called in laymans terms:
"the pedal dance"
and yes it can be very difficult to hit it exactly right until you've done it a couple times ;o)
  • Posted 28 Feb 2013 21:43
  • Reply by swoop223
Hi , 7777 have right but it is importend you begin the stopwatch as you switch on then 3 seconds wait before press 5 times in 5 seconds , then the stopwatch by 15 seconds you press it for 10 seconds to totally 25 seconds
  • Posted 28 Feb 2013 06:53
  • Reply by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
probably a battery related code
  • Posted 28 Feb 2013 06:25
  • Reply by 7777
I've never heard of a code for the starter am curious as to what code you have displayed??
  • Posted 28 Feb 2013 04:32
  • Reply by kevin_t
clearing codes for K21 - K25 engines
1) turn key switch on, after 3 seconds fully depress acc. pedal 5 times w/in 5 seconds.
2) after 7 seconds, press and down acc. pedal for about 10 seconds, until hour meter starts blinking.
3) release pedal and push down again, hold for another 10 seconds
4) hour meter should be on w/ no codes
5) shut off key, and turn back on w/ no codes.
use a stop watch.
If that dont work, remove the battery cable over nite.
  • Posted 28 Feb 2013 02:54
  • Reply by 7777
hi , it is easy with connected to laptop , other way is with the acc pedal ,but difficult. give your mail , i send you doc for reset with the pedal, what code you have??
  • Posted 28 Feb 2013 02:22
  • Reply by gc_d
Regards gc_d
