Toyota 8FGCU30:
Hour meter on display inop
I have a 2016 8fgcu30 with no hours on screen an with analyzer hooked up hours never change while running also swapped ecm, oil pressure sensor seems to run fine an systems all work any ideas would be hugely appreciated
  • Posted 15 Feb 2023 00:57
  • Discussion started by Tim_Eldridge
  • Illinois, United States
Tim Eldridge
The hour meter my have not been turned on when machine was deliverd when new there is a menu when going in to analyzer to turn hour meter on your unit my be in demo mode when put in service they turn off demo mode and that starts the meter to run
  • Posted 19 Feb 2023 02:54
  • Reply by timothy_k
Fuses an display and all that are good after removing oil pressure sensor wiring traced it back wire splits to 2 an 1 runs to low voltage disconnect our company has added on Thanks input
  • Posted 16 Feb 2023 23:33
  • Reply by Tim_Eldridge
Tim Eldridge
There's possibly an issue with a fuse blown. The serial number and machine build could be in the era of it being either a fuse and or a on with analyzer functions. Any way to switch out a display with a known good one? To eliminate harness... etc. have had 2 in about 1k machines that all of a sudden just quit working. Maybe just best after the troubleshooting doesn't find the issue is replacement. That was our 2 repairs to resolve the issue.
  • Posted 16 Feb 2023 23:28
  • Reply by ron_k
  • North Dakota, United States
4kliftman
edition #1228 - 1 May 2025
