Hobart Chargers
Hi - anyone have any experience with these, or know how to contact the manufacturer?
  • Posted 12 Feb 2025 09:06
  • By Battman
  • joined 12 Feb'25 - 3 messages
  • Alberta, Canada
Have a good day!
Hi. I'm an EE specializing in Lithium batteries. I know not all Lead-Acid chargers are compatable with all Lithium batteries, and it matters. In this case the voltage for FLA matches up pretty closely with the Lithiums, and equalization is not necessary, nor will it work (the batts will detect a higher voltage and shut off). It will charge them more slowly than an equivalent Lead-Acid in the last 20% of the charge, but that's okay - they just need an overnight charge.
It's quite possible there's something wrong with this charger however, and I'm not familiar with it - slightly intimidated, actually - so I thought I'd see what some common issues are, so I know where to look. Thanks.
  • Posted 18 Feb 2025 04:34
  • By Battman
  • Alberta, Canada
Have a good day!
Battman,
LI batteries charge at a different rate than lead acid. You should talk to the charger and battery reps to make sure they are compatible. Good Luck.
  • Posted 18 Feb 2025 03:56
  • By Fishmech
  • Virginia, United States
Hi. Thanks. We are putting a Lithium battery into a pallet jack. I'm mot sure if the charger was working previously, so will keep you posted.
  • Posted 18 Feb 2025 03:50
  • By Battman
  • Alberta, Canada
Have a good day!
Battman,
Go to hobartparts.com/manuals, they list multiple manuals and contact info that should help. Make sure to check all fuses, including any around the control board. Do not put a higher amperage fuse in as this could possibly damage the charger. Good Luck.
  • Posted 17 Feb 2025 23:05
  • By Fishmech
Claire Grossmann Claire Grossmann
Secretary general , FEM - European Materials Handling Federation
Chief revenue officer, Corvus Robotics
EVP corporate affairs & brand, Konecranes
Senior vice president, Crown Equipment
edition #1264 - 15 January 2026
In this week’s Forkliftaction News , we look at the top five robotics trends forecast for 2026 from the International Federation of Robotics, and it’s an eye-opening read with the potential for robotics, AI and automation to work together to change our sector in fundamental ways... Continue reading
Maxlion FB30EH
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Arnold, MO, United States
