Hight switch 1
Hello everyone I have a problem that I can't figure out the hgts1 is always at 1 ( carriage above the mast )
I tried replacing the switch and it not that. I've notice I only have a positive coming in no negative. So now I'm trying to figure out what is driving this switch.. witch controller could be causing the problem. Because I can't lift saying I need to calibrate tilt switch and can't learn tilt switch if hgts1 is above mast.
Thank you very much
  • Posted 16 Dec 2022 01:59
  • By vincent_l
  • joined 27 Jul'14 - 10 messages
  • Quebec, Canada
Check the function of the switch by manually moving the switch. Zero is in free Lift 1 is above free Lift. If the number never changes the wiring may be bad or miss wired.
  • Posted 23 Jun 2023 05:56
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
hi, vincent
were you able to trobleshooting that problem.? I m working on an silimar one. forklift doesn´t lift mast, and ask for tilt sensor calibration, and when try to do it, it is not accepted. it doesn´t matter hgts1 is open or closed.
Thanks.
  • Posted 22 Jun 2023 03:18
  • By roldan
  • joined 22 Jun'23 - 3 messages
  • nuevo leon, Mexico
creativity is intelligence having fun
Sometimes it takes a couple of tries to get the calibration to take. There's two things ga that the module looks for...angle and voltage. If it's always at 1, is the wires backwards? What voltage is supposed to ve supplied, negative or positive?
  • Posted 16 Dec 2022 14:15
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Lift Tek Elecar
