HERTNER AUTO 6000 CHARGER 36V
Started burning fuses.I replaced insulaters in fuse block.replaced fuses,[2 300 amp].It worked fine.a week later,stoped chargeing.Starts to charge ,Then shows fault.No fuses blown.Diodes check good. Any ideas? manual? Thanks Kent
  • Posted 9 Mar 2012 09:47
  • By kent_w
  • joined 5 Jan'12 - 102 messages
Yes,Ive done just that.I dont know, If they,ve been repaired.Kent
  • Posted 15 Mar 2012 11:33
  • By kent_w
if you dont find the obvious
blown D/C fuses
blown A/C fuses
then call a qualified Hertner Tech and have them repair it(ESPECIALLY if you dont have the manual that is usually enclosed inside the door!)
i know most customers think us forklift tech's are 'all knowing and all doing' but in some cases its not worth the risk of being electrocuted or creating a meltdown with a customers piece of equiptment. ;o)
  • Posted 14 Mar 2012 20:42
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
No fuses are blown now.Just doesnt charge,before the chargers a chance to charge.It cuts off.LCD screen shows fault.Thanks Kent
  • Posted 14 Mar 2012 08:20
  • By kent_w
If they'll work long enough to test, I'd hook up 2 forklifts for charging & test input & output of chargers. I'd then swith the forklifts & test again. If they're blowing fuses, they're either getting insuffecint power or putting out to much. This test will give you a directrion to follow.
  • Posted 14 Mar 2012 00:57
  • Modified 14 Mar 2012 00:58 by poster
  • By bbforks
Yes,they have swithed lifts from one to the other,Chargers. They are 3 phase,I ll check that..I d say,They are the same age. Im fairly sure they both have the same problem.the first one started blowing fuses,Fuses would burn up on one end.From being hot.then stopped chargeing alltogether.They are on seperate power outlets. Thanks kent
  • Posted 12 Mar 2012 23:26
  • By kent_w
Are these 3 phase supply? As both are faulty you may have a phase down on the supply, just a thought.
  • Posted 10 Mar 2012 20:51
  • By AndyPandy
Company has 2 of the same charger & both are acting up? Are they the same age? I assume the chargers are for 2 forklifts? Is each charger dedicated to a unit or do they mix & match chargers? Are the chargers on the same power circuit? If you replace fuses, do they charge long enough to run some tests?
  • Posted 10 Mar 2012 12:11
  • By bbforks
Yes it is a regulating charger.Made by Exide.Batterys are good.,connectors ,cables are fine.no aparent problems with batterys.before last charger quit working,other than blowing fuses.They chargered as expected.company has to of these charges.Both are now causing same problem.Kent
  • Posted 10 Mar 2012 08:59
  • By kent_w
I'm not familiar with this charger. Is it an electronic self regulating type? What's the conditin of the battery? How long was the charge lasting before this situation started?
  • Posted 10 Mar 2012 00:38
  • By bbforks
Deborah Baker Deborah Baker
