Help. The forklift is turned off during work
The forklift is turned off during work.
The screen reads: starter interlock engine shutdown.
Thanks for the help.
Roei
  • Posted 20 Sep 2018 20:51
  • By roei_k
  • joined 20 Sep'18 - 11 messages
  • Israel
this unit doesn't have the factory fork track system for impact. what is the s/n. please check under seat wiring may have damage wires.
  • Posted 28 Sep 2018 06:02
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
Thank you for your response.
This forklift does not have the magnetic sensor of the engine cover.
That's the first thing I was looking for.
  • Posted 22 Sep 2018 07:10
  • By roei_k
  • Israel
it could be as simple as the bonnet sensor.small magnetic reed switch in behind the battery.that will give you the message you state
  • Posted 21 Sep 2018 03:33
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
Unfortunately I do not have any fault code.
The forklift is turned off and can be started only after about 30 minutes.
The importer says it could be that it comes from the EGR. it could be?
  • Posted 21 Sep 2018 02:43
  • By roei_k
  • Israel
are you seeing any fault codes? Sounds like you are loosing power for a short period of time. Check the battery and all cables. The starter interlock is telling you that start is out of sequence.
  • Posted 20 Sep 2018 22:30
  • By BREWSKI
SMV (Konecranes) 4632CC5
Tusk 500PGH16
