Help for fault reading
Dear Sir,
I have Doosan forklift G20G model. please let me know how I can get machine fault on display
  • Posted 20 Feb 2019 21:06
  • By Anurudha0001
  • joined 20 Feb'19 - 1 message
  • Sri Lanka
1-2 (one then two) blinks means there are no more faults logged, you must be reading it wrong.
  • Posted 4 Aug 2022 02:53
  • By andrew_k
  • joined 17 Mar'07 - 336 messages
  • England, United Kingdom
Mine blinks once then two more times and then a pause then blinks seven more times then repeats its self. Does anyone know what that mean?
  • Posted 4 Aug 2022 00:54
  • By Gotcha2000
  • joined 15 Dec'17 - 42 messages
  • Indiana, United States
Gotcha2000
With key on, cycle the throttle pedal 3 times and observe the MIL light for flash codes. Codes should be three number codes with 12 code meaning end and start of sequence.
If the pedal cycle does not work try cycling 5 times instead.
Cycle 10 times to clear codes.
All cycling must be completed within 5 seconds.
  • Posted 3 Mar 2019 10:00
  • By tom_p
  • Alberta, Canada
Oxford Ct, United States
