heli forklift transmission removal
I have an 08 Heli 5k lift. I had one of my drivers who claims to be an ace mechanic remove the flywheel weight and install the factory upgrade because the teeth kept breaking off from the ring gear. Anyway, when he put the engine back together with the transmission the machine will not move. I have a feeling that the pump is damaged inside of the transmission. I have removed the engine and the torque converter and I need to remove the trans from the differential. Do I need to remove the axle shafts or will the transmission come right out. Thanks for any and all help.
  • Posted 29 Apr 2012 08:24
  • By redrock
  • joined 29 Apr'12 - 3 messages
  • Utah, United States
the engine was half way out anyway because we were changing the fly wheel ring gear. But to get to the pump you only need to remove 9 bolts from that back of the trans input shaft.
The after service person from Heli feels that there is a broken gear in the charging pump. I removed the charging pump and I cant see how there could be any gears in it. It is more like a water pump with the impeller pressed in. But I cannot get in to it to see it.
  • Posted 1 May 2012 08:26
  • By redrock
  • Posted 1 May 2012 08:23
  • By redrock
You will need to remove the half shafts. Did you check for any pressure before you removed the engine?
  • Posted 29 Apr 2012 18:28
  • By forkinlift
  • joined 22 Jan'11 - 57 messages
  • Bucks, United Kingdom
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
UN Forklift FBT18NQZ1
UN Forklift FB25N1LZ1
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
