heater malfunction
I got a forklift that the door mounted factory heater only works when the wiper is on has any seen this before that can point me in the right direction
  • Posted 24 Jan 2024 10:39
  • By Pupupuputter
  • joined 6 Mar'19 - 11 messages
Pup,
Check the cab light ground wire as this is used for all fans and lights inside the cab for ground. A failed connection can cause this issue. All cab fans and wipers are connected through the same positive and negative wire connections. Good Luck
  • Posted 30 Jan 2024 05:40
  • By Fishmech
  • Virginia, United States
Mitsubishi Logisnext FD25T5M
Mitsubishi FGE35AT
