have a 1/8 inch gap on drive tire after install
when installing a drive tire assembly hub will not seat onto the bearing adapter causing a 1/8 inch gap have any techs had this problem before is it possible that the hub is worn down or the bearing adapter needs replacing we have our hubs pressed in by a local crown dealer they are not new hubs thanks for time
  • Posted 15 Oct 2021 20:30
  • By wd62
  • joined 15 Oct'21 - 3 messages
  • Tennessee, United States
warren dellinger
slingers on each side inside bore is 5 and a half inches
  • Posted 21 Oct 2021 20:15
  • Modified 21 Oct 2021 20:17 by poster
  • By wd62
warren dellinger
there are 2 different thickness drive hubs
does your drive unit use the slingers, either side of main gear where axle runs through
  • Posted 21 Oct 2021 19:23
  • By crownie
  • Victoria, Australia
Thanks when I get to work today I will give that a closer look have a great day
  • Posted 19 Oct 2021 03:55
  • By wd62
warren dellinger
I've received drive tire assemblies that have had damaged hubs. I've also seen bearings and bearing adapters fail. I would remove drive tire and put a tape thru the axle bore. Compare measurement with known good wheel. Then inspect bearing adapter for damage
  • Posted 19 Oct 2021 03:34
  • By Triggs
JLG G12-55A
Toyota 8FG25
JLG G12-55A
Toyota 8FG25
