hard to start
i have this forklift is hard to star and when it starts it goes ok butin few seconds loose power and dies. can anybody has this problem before. what i need to do.
  • Posted 19 Apr 2011 06:00
  • By wence
  • joined 23 Mar'11 - 8 messages
lets do it
I have seen this happen also. Usually its a fuel delivery problem due to clogged final chance screen located underneath lpg pressure sensor or clogged filter in lockoff. As MEngr instructed check other sensor reading with either pda, laptop or hand scanner. If lpg pressure remains in range, check final chance filter located benath sensor. If clogged, clean but take care to not contaminate injector holder by letting debris get beyond screen. Screen is held by small clip. Do not damage screen. If pressure falls out then check fuel filter in lpg lockoff. If clean you may have vaporizor going south or the lpg lockoff is dropping out and test should be performed to verify. Remember ALWAYS drain regulator/vaporizor as recommended..
  • Posted 13 Nov 2011 02:48
  • Modified 13 Nov 2011 04:04 by poster
  • By RCAV8TOR
  • Alabama, United States
wence;
Remove the cup holder from the dash and uptape the OBD II plug. Using an automotive OBD II handset look at the other engine sensors along with the MAP sensor that you cleaned. If all sensors are reporting good check the LPG fuel pressure for 4,6 - 4.8 psi. When was the fuel filter at the lock - off last changed and when was the fuel filter inside throttle last cleaned. Also has the tar been drained from the vaporizer/regulator at a regular basis. Check to be sure the fuel relay is making with key switch on and not activating only in starting mode. While checking relay also look to be sure the relay mark EGI is making. Check the injector driver for condensation under the plug. Driver is located next to the ECM under the battery.
  • Posted 21 Apr 2011 09:43
  • By MEngr
  • Missouri, United States
i clean it and is running ok but the first time i crank it i start ok adn the second time i try it takes a delay but star and runs good and that is what is doing now takes a delay to start
  • Posted 21 Apr 2011 00:04
  • By wence
lets do it
wence;
Look at MAP sensor's readings closely.
  • Posted 19 Apr 2011 06:04
  • By MEngr
REPOWERTEK Inc
REPOWERTEK Inc
Toyota 3FD100
Crown SX3030TT4250
Esie Cortez Esie Cortez
