This machine would not start. After reading the threads, I removed throttle body and motor, cleaned, replaced gasket, removed the small injector at the base of the trhottle body, cleaned and installed. Engine started but is really lazy in revving the engine. After idling for approx 20 min and barly using the hydraulics, I could barely touch the hydraulic tank, the oil was that hot. Also noticed the mast would creep up. The engine does not sound like its under load and hydraulics work. I'm fairly certain that I have a faulty relief valve, but considering the price want to know of anything to check. I have the control valve o the bench installing new tilt spring and orings.
Serial # 10129
