Linde (& Baker) H80D-900-02:
h80 353 series
Fork lift was moved from a different location to ours with no records. OK to the issue. I was having a no start problem. there was a fuse bad. operated good for 1 week then a no start occurred. Traced that to the BRAKE SAFETY SWITCH. replaced that. no it starts but will not go in drive or reverse. hydraulics are working and there were no issues with the brakes or drive before it went down for the BRAKE SAFETY SWITCH. now stuck on where to go forward with.
thank you
  • Posted 14 Jun 2018 04:32
  • Discussion started by JasonWC
  • Minnesota, United States
Yes, it very much feels like it thank you I will check that out in the next few days when I get to it and let you know the results.
  • Posted 20 Jun 2018 20:26
  • Reply by JasonWC
Jason M. Carney
I would be checking the brake pressure when the pedal is released.
on the back of the block where the pedals go there is a a hose marked BR, check the pressure when the pedal is up. It should be around 21 bar ish. If not I would say that is why you have no drive.
Sounds like you are trying to drive against the brakes
  • Posted 20 Jun 2018 07:11
  • Reply by Lindetech
  • Auckalnd, New Zealand
EDIT:_: to answer the question. NO. the park brake is a foot brake and there is not a light that is going on or off in conjunction with the park brake.
The potential lights I have are 11. ( I wish this would allow me to attach a picture)
the top half of them are
from left to right in a half circle form.
1. trans oil
2. hyd fluid.
3.engine oil
4. left and right arrows
5 battery light
6.fan symbol
7. power symbol
the lower 4 are.
1. and up wards arrow (don't know the symbol)
2. glow plugs.
3. fuel light
4. downwards arrow(don't know the symbol either)
The only light that comes on is the battery light. no other lights any where switch on or off when the parking brake is engaged or disengaged. This parking brake is a foot pedal style with the spring plate and the hand lever on the left side of the column that allows the pedal to be disengaged. I do not see any sensors for it except the brake switch that is actuated when the pedal is depressed.
Also, thank you for responding and assisting. It is much appreciated.
  • Posted 16 Jun 2018 05:22
  • Modified 20 Jun 2018 03:42 by poster
  • Reply by JasonWC
Is the parkbrake light going off when you release the handbrake?
  • Posted 15 Jun 2018 21:54
I simply had the brake pedal in the fully disengaged position.
  • Posted 14 Jun 2018 21:07
  • Reply by JasonWC
Did you remove the brake pedal from the shaft when replacing the brake switch?
  • Posted 14 Jun 2018 20:44
edition #1234 - 12 June 2025
