H25D hyd problem
Hi you Linde experts Im hoping you can help with a hyd problem I was asked to look at today. Customer says that when the hyd mini levers are worked his truck slowed down and would hardly drive also the lift tilt and side shift functions were slower. When I get on site he says its working fine now., never the less I run it up and down the yard for an hour but I cant reproduce the problem he was experiencing.
I asked the customer if he noted any fault codes that might have shown on the display consul located up in the right hand top corner of the truck, He said L221 and large electical symbol (lighting strike) could any one tell me if this is a fault code and what it means.
A problem unresolved will probably come back on Monday
Regards Titus
  • Posted 14 Aug 2010 05:42
  • By Titus
  • joined 6 Jul'10 - 185 messages
Hi Jolo,
The problem was an itermitten one the truck works in a dusty enviroment and I think some dust may have got minto the mast tilt pot unit but worked its way out, the truckappears to be operating ok now. Nacsnd N gave me info which aws most helpfull.
Titus
  • Posted 21 Aug 2010 04:49
  • By Titus
Hi Titus,
Did you resolve the L221 fault code on your customers Linde truck
  • Posted 19 Aug 2010 17:45
  • By jolo
  • joined 19 Aug'10 - 5 messages
  • South Yorkshire, United Kingdom
Thankyou Nacsand for your quick reply, could you possibly tell me where the sensor may be located and what type of sensor it is. Is it a wire wound type or an optical type
is it located on the mast or the truck chassie.
Im afraid I cant help you with your BT problem I dont know much about them.
Regards Titus
  • Posted 15 Aug 2010 21:18
  • By Titus
Hi Titus,
This rror code tells about an error in tilt angle sensor, check the sensor and conections.
Regards
  • Posted 14 Aug 2010 08:57
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Toyota 8FG25
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
