Gp030 motor removal
Hello all,
I have a Yale gp030 with the Mazda motor. Need to remove transmission, got bell housing unbolted, starter out, accessories, etc.
What's next? Ujoint drive off the front to pump? Torque converter?
  • Posted 17 May 2018 09:29
  • By Dweazel
  • joined 17 May'18 - 3 messages
  • Colorado, United States
Do the trans and differential come out as one unit?
  • Posted 31 May 2018 23:34
  • By Dweazel
If you need to remove the transmission you can leave the motor in. Remove mast, brake lines and cables, bell housing bolts, torque convertor bolts, linkages and wires to trans, the caps that hold the axle assembly to frame, support the motor, and pull the transmission out the front.
  • Posted 17 May 2018 19:24
