Governor eliminate or bypass?
FG25T-8, NISSAN MOTOR
Having issues with idle, timing, acceleration.
What's been done-
Cleaned carb thoroughly, new cap, rotor, wires, plugs, new distributor, gaskets at carb, timing checked and can not dial in.
Verified vacuum leak with gauge-vac loss found at governor when cover removed and used brake cleaner to snuff out. When sprayed inside. When running unit idles high due to lean condition, does run smooth, idles at 1100RPM or so.
My question is and be mind full this is used in minimal farm/home use not commercial, IE- low cost operation. Can it be bypassed and used with out the governor, obviously be careful not to float the valves? What is the best affordable way to rectify this situation.
  • Posted 7 Apr 2024 08:46
  • By CJ_Dubbels
  • joined 7 Apr'24 - 1 message
  • Idaho, United States
20HMFIC
Have you verified the points are set?
Sounds like the dwell is off.
There are electronic ignition kits available from pertronix to replace the points.
I'd be scared to overrev an engine this old. They aren't really available anymore and if a rod goes through the block it won't be getting fixed.
  • Posted 7 Apr 2024 21:29
  • By stam
October 12-15, 2026 - Detroit, MI, United States
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
UN Forklift FBR25NQC3
Hangcha CBD15
China
USD1,600
Stu Jacover Stu Jacover
Chief executive officer, TVH
Hangcha CBD15
China
USD1,600
