going into limp mode under acceleration
fgc15n is going into limp mode under acceleration.If you accelerate real slow it will run fine but if you make any quick movement of the pedal it goes in limp mode with no codes on forklift or laptop just the ! on the dash panel.
  • Posted 17 Feb 2017 03:01
  • By dirtwheelman
  • joined 17 Feb'17 - 2 messages
  • Tennessee, United States
could have filter in manifold have a look under plate above assist injector if it's got one its right at the bottom held in with a circlip also worth stripping lock of valve as they tend to stick otherwise try adjusting vaporizer
  • Posted 17 Feb 2017 19:49
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
we checked the gas filter its a 2011 we saw a drop in pressure at the intake when it happens watching the live data so we changed vaporizer but still doing it.
  • Posted 17 Feb 2017 06:47
  • By dirtwheelman
check the gas pressure have you changed the gas filter what year is it the older ones used to have a filter in the injector manifold
  • Posted 17 Feb 2017 06:29
  • By alanmitsi
Yale Lift Truck Technologies
