Glow plug problem
I have a FD30T-14 with a yanmar engine. I have replaced all glow plugs and the glow plug timer controller box. The glow plug light still does not go off. What would cause this problem and what is the fix
  • Posted 15 Jan 2016 09:53
  • By vbar
  • joined 17 Nov'15 - 17 messages
Hey Vbar, I never seen that could be that it is only for US market.
  • Posted 21 Jan 2016 19:49
  • By marcb
  • joined 10 Jun'14 - 222 messages
  • ANTWERP, Belgium
Does the box that is marked Engine Check have anything to do with this problem. What does this box do
  • Posted 19 Jan 2016 01:42
  • By vbar
Vbar, on the right side there's a cup holder with a hole in it, when it gets wet the water falls on the plug under need the cup holder. We had that problem several times.
Have you controlled the relay?
Regards
Marcb
  • Posted 16 Jan 2016 02:38
  • By marcb
  • ANTWERP, Belgium
No we have not washed the unit at all yet
  • Posted 16 Jan 2016 00:57
  • By vbar
Hello Vbar, Have you cleaned it with high water pressure? remove the right front cover from the dashboard. there's a plug make it dry with air pressure.
Regards
Marcb
  • Posted 15 Jan 2016 18:21
  • By marcb
  • ANTWERP, Belgium
Big Joe PDR30-154
USD7,500
Maxlion FG25
