Glow-plug indicator
Indicator is on but glow-plags are OK, rele is OK, thermostatic switch is OK..
What else can be wrong??
thanks
regards
  • Posted 7 Sep 2014 02:01
  • By TANTADRUJ
  • joined 13 Oct'13 - 103 messages
  • ljubljana, Slovenia
Showing items 1 - 18 of 18 results.
What cable do you need to conect Path finder to Particle filter (reset)??
  • Posted 30 Sep 2014 04:05
  • By borut_veliki
  • joined 14 Dec'13 - 64 messages
  • novo mesto, Slovenia
Yes, it exist. you were wright. It's the vw cord 300 365 2503 for diesel and the vw cord 300 365 2504 for LPG.
I got it all the time but newer use it.....forgot about it.....
thanks
regards
  • Posted 18 Sep 2014 09:11
  • By TANTADRUJ
It connects in the same place as the standard pathfinder cable. It enables you to connect with cam/crank sensors, fuel injector pump timing settings etc.
Trust me, this does exist!
  • Posted 16 Sep 2014 15:01
  • By little_forker
  • joined 31 Jul'11 - 82 messages
And where is that engine controler connector??? There is only extra Particle filter connector and that is all!!
  • Posted 16 Sep 2014 00:17
  • By TANTADRUJ
There is one cable for connecting to traction/hydraulics/steering/display then additional cables for connecting to the engine controller.
  • Posted 15 Sep 2014 16:08
  • By little_forker
There is just one type of cables for LPG and Diesel for Pathfinder. You are totally cnfused.
  • Posted 15 Sep 2014 07:13
  • By TANTADRUJ
You will need to contact Linde for either a part number for the cable, but it will probably be easier and cheaper for you to get a linde engineer to come out. I don't have a part number for the cable (I don't work with them anymore!) but I know they have different cables for LPG and Diesel engines.
  • Posted 15 Sep 2014 06:46
  • By little_forker
yep little_forker i see that
the EDC flashes the glow plug indicator if a stage 2 fault is detected.
so yep, he will need pathfinder or whatever program DiagRA-CE is to get a detailed view on whats happening.
  • Posted 15 Sep 2014 00:34
Can you give me link to this cable? And what can be wrong with angine?
  • Posted 14 Sep 2014 17:24
  • By TANTADRUJ
Glow plug relay light staying on = engine fault. This module has an additional controller for the engine and needs a special cable to connect to it using pathfinder. You cannot connect to it using standard pathfinder cables.
  • Posted 14 Sep 2014 17:20
  • By little_forker
......Indicator is on but glow-plags are OK, rele is OK, thermostatic switch is OK....
  • Posted 11 Sep 2014 03:29
  • By TANTADRUJ
glow plug relay stuck closed?
  • Posted 11 Sep 2014 03:15
what do you have in mind??
  • Posted 11 Sep 2014 02:27
  • By TANTADRUJ
Do you have the correct cable for connecting with the engine?
  • Posted 11 Sep 2014 02:24
  • By little_forker
what foult?? no error is shoven. i have pathfinder.....
  • Posted 11 Sep 2014 00:38
  • By TANTADRUJ
This can be an engine fault indicator, have you got access to pathfinder?
  • Posted 10 Sep 2014 22:15
  • By little_forker
h2x392u02887
  • Posted 9 Sep 2014 06:19
  • By TANTADRUJ
Serial number?
  • Posted 9 Sep 2014 05:50
  • By little_forker
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Elwell-Parker ESI500-36
Unicarriers FHGE35T5S
Lithium Storage
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
