Gate shows on display No forward, reverse and lift OK
I have Gate showing on display, truck will not go forward but will travel reverse and lift, any Ideas?
  • Posted 24 Mar 2016 00:11
  • By Jumpinjoe
  • joined 24 Mar'16 - 6 messages
Ok, we have everything eliminated...except the forward circuit. CA204-1 and CA204-2 on the distribution board are the switch outputs for forward and reverse. Reference battery negative and check CA204-1 for battery volts when requesting forward travel. If ok, put + meter lead on forward contactor coil, if ok...then contactor coil is bad
  • Posted 17 Oct 2017 03:09
  • By Ifixit
I removed and replaced all connectors, no improvement. Still no forward. Reverse and lift work fine. Is there something I can swap between forward and reverse circuits to see if problem moves?
  • Posted 17 Oct 2017 02:54
  • By Jumpinjoe
On the distribution board, unplug...then plug in al the connectors. 80% of "gate"/"center handle" on display is caused by poor connector pins. Even a brand new board and connector can throw that fault
  • Posted 16 Oct 2017 02:45
  • By Ifixit
New forward contactor same problem, truck has new battery voltage not an issue
  • Posted 14 Oct 2017 06:20
  • By Jumpinjoe
Check fwd switch, all other circuits have to be good to have reverse travel. A bad contact or will click but no travel and wont show code. If you lose signal anywhere before a fwd or reverse switch output when the controller senses throttle voltage with no direction input it shows gate. Can be gate switches at times but that would affect both directions.
  • Posted 5 Nov 2016 02:07
  • By robert_e
  • joined 25 Oct'16 - 13 messages
"gate" can be
gate switches
gate switch relay
brake pedal switch
brake module
poor connection at distribution board
in your case i would suspect the forward switch has failed
  • Posted 24 Apr 2016 14:34
  • Modified 24 Apr 2016 14:36 by poster
  • By crownie
  • Victoria, Australia
If I remember right the F/R contactors will show no error just not move one direction because either one contactor is not closed completely or the other is not open/actually in the reverse closed position completely.
Probable cause is the forward switch sticking if the reverse switch was not working you would get a center handle message.
To Crown a Gate is just a term for a open circuit. If it was a gate switch then it could not have everything working but the reverse travel.
  • Posted 21 Apr 2016 08:39
  • Modified 21 Apr 2016 08:43 by poster
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
Sometimes it will give the error gate, but it's not the gate, check contractors and fwd and reverse switch in handle assembly, the contractor is similar to 50fc for faulting
  • Posted 20 Apr 2016 19:36
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
I will check switches but I believe they are OK because the truck will lift without throwing a code, it also travels in reverse. trying to move forward is the only thing causing an error.
  • Posted 5 Apr 2016 07:27
  • By Jumpinjoe
Gate is for the gates on platform if either is up it will not let you do anything. Remove platform cover and check switches. If they are ok check K3 relay on distribution panel of power unit. Gate signals run through it. Last is drive / tow switch on panel if someone released brakes with it and did not switch it back it will say gate also
  • Posted 26 Mar 2016 09:13
  • By popeye
Terberg RT223
Taylor T520M
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Terberg RT223
Taylor T520M
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
