FW and 1A pull in together
Replaced card and drivers checked wiring 1 and 3 Rec good any more ideas would be greatly appreciated
  • Posted 21 Nov 2023 05:37
  • By FFJim
  • joined 24 May'11 - 11 messages
  • New Jersey, United States
FFJim,
what make model and serial number is this EV100 in?
and what is the IC number on the card you put in it?
These cards will run when you install them but the base settings sometimes are not correct for your machine, not all mfg's set them the same.
  • Posted 23 Nov 2023 15:37
You say they pull in together. Is that after reaching top speed. FW pulls in after 1A and motor current field and armature ratio commands it on a non-LX control. You should also have a FW adjustment on the control card. If you don't have literature on your system, Check into Flight Systems (FSIP) free documents. Highly recommended.
Note: checking the current sensor connections is also advised.
  • Posted 23 Nov 2023 06:03
  • Modified 23 Nov 2023 06:03 by poster
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
Elwell-Parker ESI500-36
Nagano NUZ090D
