That's what some people was saying
What needs to be glued in a regulator rebuild
check to see if the injector is plugged with tar. I remove them and soak the tip in a cap of b12 or brake clean. You can also crank while doing this, if you dont see bubbles then its non operational
I have fuel going to injector but not sure if the injector is firing. It has a hard time to start when it sits over night. Can spray Barkley into mixer starts up and runs fine. Anything you can help. Regular was just rebuilt but didn't touch the adjustment needle.
So you don't have fuel getting to the regulator? Have you verified the main fuel solenoid is operational
