Front and reverse very slow
Puebla, Mexico Hi friends, this time i have a problem with a Hyster E60z-33. Front and reverse is very slow and there isnt a code error in the display. Motor is OK.
Serial Number G108VO2478B
Thanks for the help!!
  • Posted 1 Feb 2012 15:53
  • By oswaldomartin
  • joined 14 Oct'11 - 8 messages
  • Puebla, Mexico
Sensor bearing failure for sure.diagnosis via the dash. Traction motor current will be sky high
  • Posted 19 Aug 2012 22:17
  • By kevin_k
checked the brake switches yet?
  • Posted 19 Aug 2012 08:04
Some time the Sensor Bearing can cause this and motor will need to be repaired. Sensor bearing replaced
  • Posted 18 Aug 2012 06:25
  • By Techhelp
  • joined 16 Apr'10 - 22 messages
  • Wisconsin, United States
Have you checked what mode it is in. Mode 1 slowest - mode 4 fastest
  • Posted 8 Feb 2012 08:18
  • By sean3
  • joined 14 May'11 - 46 messages
  • lancashire, United Kingdom
