Front and reverse very slow
Puebla, Mexico Hi friends, this time i have a problem with a Hyster E60z-33. Front and reverse is very slow and there isnt a code error in the display. Motor is OK.
Serial Number G108VO2478B
Thanks for the help!!
  • Posted 1 Feb 2012 15:53
  • By oswaldomartin
  • joined 14 Oct'11 - 8 messages
  • Puebla, Mexico
Hi friend, i'll try what yo say. I'll try to switch off the output of the bearing and check values. Do you know which is the value range for the proper functioning of the bearing output? and so will I know if this decomposed.....
Thank you so much!!!!
  • Posted 5 Feb 2012 03:13
  • By oswaldomartin
  • Puebla, Mexico
troubleshoot via the dash.you,ll prob find that drive motor current is sky high. very slow drive both directions is a good sign of encoder bearing failure. remove battery and bearing is installed in the end plate of drive drive motor. can be replaced without removing the motor
  • Posted 4 Feb 2012 19:26
  • By kevin_k
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Enforcer FD50T-MMA
USD1
Enforcer FD50T-MMA
Sue Tomic Sue Tomic
