Forward and Reverse Max Speed not reachable
I have 3 Linde H35Ds with VW turbo diesel engines, 2 with brand new turbos, and one with a brand new engine, (thanks to Linde for supplying with a new engine after just 3200 hrs).
The problem I am getting is that 2 of these lift just can not obtain their full driving speed as they should (maybe 35% if were lucky)
ECU configured correctly
No error codes
Complet hydrolic pressure check - all within specs
New ECU - no difference
New turbos - no difference
New fuel injectors - nothing
New speed pedal potentiameter sensor - nothing
Complete fuel, oil, air filter and hydrolic oil change - nothing
Linde certified mechanic - stumpped (no help)
The only decernable difference with my only one that is ok, is that the swash-plate solinoide current at top speed is lower on the faulty lifts than on my good one.
Has any one had this problem - and if so please tell me what to do. My big busy season is hitting me hard and I have had to hire a new driver and I have had to rent a forth lift to help.
  • Posted 14 Mar 2007 05:57
  • By gert21
  • joined 14 Mar'07 - 1 message
keithatkmcforkliftdotcom
  • Posted 2 Apr 2016 01:30
  • By keith_m
  • joined 29 Jun'09 - 57 messages
Just got back on here , not sure how to contac you other then this way. Not real computer savy.
  • Posted 1 Apr 2016 11:30
  • By edward_m
  • joined 11 May'15 - 111 messages
edward can u contact me plz.email in profile
  • Posted 10 Mar 2016 01:27
  • By keith_m
keith@kmcequipment.com
Hook up a laptop and check swash plate.make sure everything is set 100%. Plus if you have new turbos, have to recode which can only be done with a lap top.
  • Posted 24 May 2015 06:01
  • By edward_m
Briefs United States
Hyster
