forklift wont turn over ????????????
I've checked the power supply to the starter, and the switch both have power. i turn the key and it wont start wont even turn over. Any suggestions ??????????
  • Posted 19 Jan 2011 08:19
  • By karl_p
  • joined 19 Jan'11 - 3 messages
Edward, Karl has proved the starter motor works but there is probably a neutral start switch in the line that may be open circuit and possibly a relay to take the load of the ignition switch, I'll admit Im not familiar with this model but I am familiar
with alot of Yale models, Gas and Diesel, trucks,
I feel you need to locate these two parts and check them out,
Regards Titus
  • Posted 20 Jan 2011 06:00
  • By Titus
  • joined 6 Jul'10 - 185 messages
when you say "come on and when i turn the key nothing", does that nothing mean the lights no longer would come on? (means the battery terminal and posts need cleaning or replacement, or the ground from the neg. post to the frame needs checking/replacement). tell us what size was the wire you connected to and how big of a jumper wire did you use, when you did get it started ?
  • Posted 19 Jan 2011 21:40
Yes it's in netrual. When i turn the key on all lights come on and when i turn the key nothing
  • Posted 19 Jan 2011 21:13
  • By karl_p
yesterday i tried hooking a cable from the positive side of the battery to the starter and it turned right over and the forklift started right up. drove it around for a few min. Cut it off and it wouldn't start back. i've checked these fuses all good. iono im lost !!!!!!!
  • Posted 19 Jan 2011 21:11
  • By karl_p
is it in neutral?
There are a few things between the key and the starter motor, and "power" is not a specific enough reading to decide anything.
If you jack the drive wheels off the floor, and then jumper (only for a small moment) between the battery positive (large cable and post on the starter) and the smaller wire on the starter, what happens?
  • Posted 19 Jan 2011 08:45
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
St. Louis, MO, United States
Louisville, KY, United States
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
