Forklift tyres - which one
Hi, i'm new in business and i have come to a problem. I must change tyres on my forklift. I have 3 forklifts. One is on pneumatic tyres and the other two are on solid tyres. I have ofers from several tyre manufactors (Sava, Solideal, Continental, Gumasol, Marangoni, Exaflex, Starco...). PLEASE HELP ME WITH CHOOSING THE RIGHT TYRE FOR ME !!! (price/performance)
Are there any indepandent tests available???
Thank you.
  • Posted 28 May 2007 15:54
  • By tadej_f
  • joined 28 May'07 - 3 messages
  • Slo, Slovenia
What an interesting topic-lifting truck tyres can be very hard to choose given the vast numbers for selection (solid, pneumatic, non-marking, etc.).
Aside from some experience with cars and vans, I recently found out that the mobile tyre fitting Newport services considered some light commercials and even industrial vehicles like forklifts. If you are not too sure about tyre types, it is a good idea to call a local mobile fitter. Some can assess your site, take the specs of your forklift, and make an appraisal of the working environment-for example, if most of it is indoors or outdoors-and then be in a position to recommend the best in relation to traction, durability, and safety.
  • Posted 28 Jun 2025 16:05
  • By Jake_Spencer
  • joined 28 Jun'25 - 1 message
  • United Kingdom
If your trucks are primarily indoors and your chewing up tires:
Clean your warehouse floors regularily.
Inspect your loading docks, make sure that the edge of the dock is not overly exposed when extended into a trailer.
Give your operators space back off of the loading dock all the way to prevent damage to the sidewalls of your tires.
Trucks driven by very abusive drivers on a clean floor can easily get 1 year of service on a set of tires.
  • Posted 23 Feb 2008 13:20
  • By theraymondguy
  • joined 23 Feb'08 - 12 messages
I have one customer that runs S155 Hysters all day over railroad tracks and pot holes. I went to a custom ITL (brand) tire with a TFT compound and man I havent had any issues. ITL and Maine tires are owned by GPX international - look them up.
ITL's come stock on all Cats and Mitsubishis and Maine comes stock on all Hysters and yales, GPX owns both of them.
If you have a decent floor run ITL with EL compound, or electric compound, it has less resistance to the ground so less heat buildup, less tire break down.
On pnuematics I use a ITL with a softtuff compound. In my opinion there is no better then ITL
  • Posted 7 Feb 2008 13:43
  • By william_r
  • joined 17 Jan'08 - 2 messages
Tadei f
My advice would be to pass the problem to your tyre dealer. Get them to see the application for each of your sites , then recommend the correct tyre at the correct price for that job. When / if the Tyre fails prematurely, you then can go back to them for compensation / bigger discounts.
  • Posted 6 Jan 2008 20:53
  • By AndyPandy
I have tested Gumasol and Solideal. They are both great tires...SO !
  • Posted 6 Jan 2008 18:11
  • By tadej_f
  • Slo, Slovenia
Strongly reccomend Continental.
  • Posted 31 Dec 2007 22:20
  • By fhsltd
  • joined 20 Dec'07 - 29 messages
  • United Kingdom
I am having problems with chipped tyres. Actually, it is an understatement. I actually have tyres that break off in chunks. My vendor keeps blaming our tractor drivers driving over sharp uneven surfaces. While I do not dispute that fact, I still wonder if the tyre quality has anything to do with it.
Our forklifts are used mainly in the warehouse. Ocassionally, they are driven out onto the tarmac.
Any advice on what to do? I am told to try Aichi, Japan. Is it much better for my kind of environment i.e. tropical climate, warehouse and uneven roadways.
  • Posted 31 Dec 2007 15:57
  • By chewingyu
  • joined 28 Oct'05 - 73 messages
  • Singapore, Singapore
Hello,
I suggest you call Tom Bliss at Stellana. He will get you what you need.
You can reach him at 262-348-5575.
Good Luck.
  • Posted 20 Aug 2007 23:28
  • By jon_a
  • joined 1 Aug'07 - 2 messages
  • Wisconsin, United States
You can't go wrong with Continental SC 15 or solideal magnum. We use Vorwerk Rota which are excellent and a good price. Forget Gumasol they have quality problems at the moment.
  • Posted 16 Aug 2007 21:21
  • By stuart_w
  • joined 16 Aug'07 - 12 messages
  • Bremen, Germany
Trac tire is the brand it is a relined ring. Have had these tires peel off the ring lots.Even when they dont they wear fast and chunk out. A good Main tire will out last them
  • Posted 30 May 2007 10:10
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
We use the ITL brand,from GPX tires at www dot gpxtire dot com
  • Posted 29 May 2007 16:27
  • By Truck_Tech
  • United States
Thank you for the answer, but i don't understand what do you meen by "trac tyre"?
Thnx
  • Posted 29 May 2007 15:08
  • By tadej_f
  • Slo, Slovenia
Stay awat from trac tires they stink big time.Continental is a good tire not had any dealing with the others hope this helps
  • Posted 29 May 2007 08:28
  • By proshadetree
Researchers at Queensland's Griffith University are credited with taking the photograph of the smallest thing ever caught on film - the shadow of an atom, taken in 2012.
March 25-26, 2026 - Brisbane, Australia
May 12-14, 2026 - Singapore, Singapore
October 6-7, 2026 - London, United Kingdom
