Forklift takes forever to start moving moves slow
Hey guys,
I have a Hyster H40H i thinks its a early 80's model. Well when I start it up and give it gas Monotrol pedal all the way down I have to hold it there for 5 to 10 mins then it will slowly start inching forward. Acts the same going in reverse. Any ideas? Read something about a inching valve. The lift hydraulics work fine.
Also if any has a pdf manual that would be cool too.
Thanks,
  • Posted 2 Dec 2014 08:57
  • By Topnotch
  • joined 2 Dec'14 - 11 messages
Hyster H40H
http://youtu.be/GsThRyEg0NM
Hi, glad you got the machine running. Check the stick for instructions on how to check the fluid level. (Most Hysters I work on indicated running and warm, but don't quote me for your model.
Jim
  • Posted 23 Jan 2015 15:58
  • By Turb0
  • joined 17 Jan'15 - 15 messages
  • British Columbia, Canada
Got it fixed. The inching valve was stuck. Took it out and cleaned it up. Video in my profile.
  • Posted 4 Dec 2014 14:05
  • By Topnotch
Ok I just got the left brake unstuck. Just sprayed some wd40 in the adjuster hole and adjusted them. Now it goes forward and backward quick but you still have to wait a little bit for it to get going. Seems like it has to build up pressure. Will be picking up a pressure gauge tomorrow.
  • Posted 3 Dec 2014 11:10
  • By Topnotch
Hyster H40H
Yep,definately looks like the brakes are froze up/sticking on the left side,with it up in the air like you have it
  • Posted 3 Dec 2014 08:56
  • By kevin_t
I have a youtube video now of what the forklift is doing. Check my profile or signature.
I think the left brake is stuck.
  • Posted 3 Dec 2014 08:33
  • By Topnotch
Hyster H40H
Not sure about the filters I did call the local hyster service company and tried to setup a service for it. Still waiting to hear back.
The main lift cylinder is leaking so I know that will need to be rebuilt.
  • Posted 2 Dec 2014 10:52
  • By Topnotch
The fluid that I got with it was NAPA brand and it has a forklift on the front. Not sure what type fluid it is i'll check tomorrow. The fluid was low but I fill it to where it showed be on the dipstick.
Not sure if it needs to be running when I check the fluid or off. Like in a car.
Also what type of gauge do I need? Can I build one from parts from tractor supply?
What about stuck brakes? It did sit outside where I bought it from.
Thanks!
  • Posted 2 Dec 2014 10:50
  • By Topnotch
Yes Thats a good serial number......one other thing ro check is the fluid level and dondition,also the filters do they need dhanged? This truck takes universal tractor dluid john deere spec J20a...not transmission fluid like in a car,has someone put the wrong fluid in it?
  • Posted 2 Dec 2014 10:35
  • By kevin_t
Won't let me post a picture of the tag.
  • Posted 2 Dec 2014 10:32
  • Modified 2 Dec 2014 10:33 by poster
  • By Topnotch
just added my email in the about me.
Serial: E003D0138B
Does that sound right?
  • Posted 2 Dec 2014 10:28
  • By Topnotch
Sounds like a pressure issue with the transmission pump or clutch packs...have a serial number of the truck....email to,put in your profile????
  • Posted 2 Dec 2014 10:24
  • By kevin_t
Zhejiang UN Forklift Co., Ltd
Maxlion R2B25LI
Maxlion FG25
