Forklift sputters like out of fuel
Got an 8fgu18 63281 serial
Unit has 5000 hrs
Last week, customer contract for sputtering in pedal. Erratic idle. Presented as regulator issue. New regulator. Problem reappeared 2 days later. Evaluate. Have checked graphite inline filter. Main lock off opens as it should. Full voltage even when unit dies down. Slow path solenoid power and ground good. Throttle body side. Have found when issue occurs can remove air intake from throttle body neck and manually restrict the throttle body and unit will run as it should. No rhyme or reason for the unit to run smooth again but it will. Today, had the unit running at about 2000 rpm's for a period of 2 hours with no interruption due to issue. 40 minutes after I left, unit had issue return. Any ideas? No codes on the dash. Swapped tanks.
  • Posted 27 Nov 2024 14:07
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
Did you hook up analyzer and set vaporizer, 02 sensor numbers and or check them. Vacuum lines, ignition parts? How new? Coil packs ?
  • Posted 29 Nov 2024 08:49
  • By ron_k
  • joined 2 Apr'15 - 144 messages
  • North Dakota, United States
4kliftman
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Toyota 8FD45
UN Forklift FB25N1LZ1
Toyota 8FD45
Lift Technologies Inc.
