Unicarriers (& Nissan) MCP1F2A25LUV:
forklift smoking
i have a code e 36 i replace lpg sensor but the forklift is smoking from the muffler. it is hard to start then start running bad and in few seconds it goes to normal then after couple minutes it starts to smoke any body knows why is this.
  • Posted 24 Mar 2011 21:48
  • Discussion started by wence
lets do it
Have seen this happen before but was under unusual circumstances. Was at a location where another tech was performing maintanence on a lift and it done as you described. Checked unit and found wire broken on lpg pressure sensor and smoke was due to not removing dipstick when filling crankcase with oil. Comfirmed this by removing PCV hose from valve cover and finding oil in it. After talking with service guy found he had not let oil have time to drain in oil pan before starting engine. Wire was broken due to wire connection checks. Repaired wire, cleaned out remaining oil in hose and cleared code. Smoked for several minutes and cleared up.
  • Posted 13 Nov 2011 06:29
  • Reply by RCAV8TOR
  • Alabama, United States
Check your coolant level in the resevoir bottle and level in radiator, bottle should be filled to marked lines on the bottle , the coolant level sensor is inside the bottle, sometimes it sticks. You can blow very low amounts of air pressure in quick shots into the top 10-20 PSI(cover with a rag). Sometimes they stick and this helps, if not take it out and wash it out with hot water,check wires and connections and try again.
  • Posted 31 Mar 2011 11:13
  • Reply by roadtech
roadthec. i just replace the lp reglator is not smoking but the houers whent off after i connect the coolant level sensor. i foud it unploged. now my question is what i need to.
  • Posted 31 Mar 2011 02:12
  • Reply by wence
lets do it
i just did it is running better. and whit out smoke. but i found the coolant level sensor disconect, i just connecte it back and the houers in the instrument cluster whent off. i unpluge the sensor and they come back on. any body knows why is doing this or what i need to do.
  • Posted 31 Mar 2011 02:05
  • Reply by wence
lets do it
what is the engine oil level? if it is way overfull, you have a seal blown in the hydraulic pump.
  • Posted 29 Mar 2011 09:43
  • Reply by edward_t
mrfixit;
Your thinking is about what I would believe is correct. This is an issue which is more likely to be cause by a sensor or sensors which are not functioning correctly. An automotive style On-Board-Diagnostic II (OBD II) handset should be able to determine this.
  • Posted 29 Mar 2011 06:10
  • Reply by MEngr
  • Missouri, United States
I never saw a forklift smoke from burning LPG fuel. Oil or antifreeze burning causes smoke.
  • Posted 29 Mar 2011 03:02
  • Reply by mrfixit
Wence;
Before we change a part which abt 800 USD and still may have warrenty if it operational life is less then 5 yrs. or less then 3000 hrs. let us install a Generic Service Tool (GST) on the OBD II link which is taped to the wire harness under the cup holder of the dash and find out which P code is being displayed so we can determine more accurately what is taking place and is the cause of the issue.
  • Posted 29 Mar 2011 01:03
  • Reply by MEngr
Replace the LP fuel regulator, it's dumping too much fuel into the system.
  • Posted 25 Mar 2011 07:06
  • Reply by roadtech
Crown CG33P5
UN Forklift FBRP15NQZ2
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
edition #1235 - 19 June 2025
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
UN Forklift FBRS15KQZ2
