forklift lift
Does anybody make a fork lift lift with a 30,000lift capacity?
  • Posted 12 Jan 2016 04:01
  • By triumphrider
  • joined 31 Jan'11 - 304 messages
We have got a 10 ton 4 post Zippo lift which is German and a 6 ton Somers two post mobile lift. We would not be without them it just makes things so much easier especially when working on big compact machines like Hyster S7.00's.
The mobile lift is also good as it a wheel free design so you can do brakes etc standing.
Whoever said about parking trucks under though has obviously never used one as there is not enough clearance underneath!!
  • Posted 20 Jan 2016 04:51
  • By danny_k
My company bought a TILT-OR-LIFT brand Lift-a-lift V-13A a few years ago. The lift is invaluable for time, convenience and safety. It was however quite expensive. There are only two things that haven't worked out the way we would like: 1 The optional attached transmission jack that we ordered with it has too much free-play in it for our liking (which makes us uncomfortable from a safety standpoint) when trying to remove the heavier components from below. 2 The wheel freeing device is a crossbar with manually cranked spiral jacks on each side of the truck...I would shop for one that has the crossbar that can be rolled front to rear and has a power jack for lifting the wheels from the platform. The lift itself works great and has been a great asset to our company; the other comments are just my evaluations as a tech and not meant to knock their product.
  • Posted 19 Jan 2016 01:04
  • By CR500R
  • joined 24 Jan'15 - 15 messages
  • Indiana, United States
hyster
yale
caterpillar
taylor
these are 4 i know of right off that carry that capacity or higher
these trucks are almost always special order (for new)
  • Posted 15 Jan 2016 05:21
The lift is not for my shop. I have a excalibur 20,000 lb lift that works just fine for this application. A company next door to us has a 24/7 operation. All units are speced out just for their operation and the need to have a fast turn around on breakdowns and general maint. They are going to build a forklift shop from the ground up and plan to do it right. I currently have 100+ lifts at my location and the lift saves a lot of time.
  • Posted 15 Jan 2016 04:08
  • By triumphrider
How often would you need to be under a forklift, most of the time these get used to store a truck on top and another underneath. In my opinion a waste of time.
  • Posted 13 Jan 2016 23:19
  • By heightlift
  • joined 19 Sep'12 - 139 messages
  • North, United Kingdom
Years ago my company installed a 4 post heavy duty electric lift where I worked as an in-house tech. It was manufactured by Rotary and they have them on their web site, up to 60,000#. We also had what they called a bridge lift accessory that ran on rails between the ramps and also had an air operated pancake jack on it. Worked very well. It is so nice to be able to stand up under a lift truck while servicing it. Later, I worked at a large dealer that also had a similar lift. They are out there.
  • Posted 13 Jan 2016 09:17
  • By bobcat
  • joined 7 Jul'12 - 15 messages
  • New Hampshire, United States
somers make something in the uk. but we dont get spoiled bylifts very often , crawling on the ground is the norm LOL
  • Posted 13 Jan 2016 04:07
  • By kevin_k
Check out tiltorlift Inc. They go up to 40,000#.
  • Posted 12 Jan 2016 07:12
  • By BREWSKI
I meant a forklift maintenance lift used to acess the bottom of the lift.
  • Posted 12 Jan 2016 06:42
  • By triumphrider
30000 kg or lbs. Hyster make both 30 ton and 15 ton product
  • Posted 12 Jan 2016 05:49
  • By kevin_k
Terberg RT223
Aichi SR18A
