Forklift Assembly
Can anyone share a how to efficiently jack-up a forklift with Hydraulics from the floor while doing assembly
  • Posted 9 Apr 2021 15:30
  • By Fardad
  • joined 9 Apr'21 - 1 message
  • India
@Fardad
Exactly what are you assembling?
how to lift the machine depends on what your trying to do, what type of machine it is, how much it weighs, etc.
  • Posted 5 Jan 2022 04:26
Identify a Lift Point, Prepare the Load for Lifting, and Chock Wheels
Before lifting a forklift with the jack, you need to identify a lift point and prepare the load for lifting.
1. Remove any load from the forks of the forklift and lower the forks to the ground.
2. Identify a lift point at the rear or side of the forklift.
WARNING! When selecting a lift point, it is very important that you consider the following:
* Position the jack so that, as the forklift is lifted, the load will be balanced on the forklift tires that remain on the ground.
* When raising a forklift from one end, always chock the wheels that will remain on the ground.
* Make sure at least two wheels of the forklift remain in contact with the floor at all times. NEVER raise a 3-wheeled forklift from the 2-wheeled end or from the side. NEVER use the jack to raise all four wheels of the forklift from the floor. NEVER raise the forklift higher than 1/4 its tread width
  • Posted 4 Jan 2022 17:52
  • By Owolabi_Moses
  • joined 4 Jan'22 - 1 message
  • Nigeria
I learn new concepts and acquire new skills reasonably fast.
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
