Fork prong does not lower
When an electric forklift breaks down midway being used, is it normal that fork prongs cannot be lowered by gravity?
It is quite a concern because:
1. it is as safety hazard when the fork prongs are protruding at mid height.
2. it adversely affects operations if this happens while cargo is being handled. It would inconvenience operations as a second forklift would be needed to lift the cargo off the first forklift.
Is this by design or merely a faulty forklift? According to supplier, to lower it, it would require mechanic to attend to it and lower it (I assume by adjusting some hydraulic valve)
  • Posted 3 Mar 2023 12:50
  • By chewingyu
  • joined 28 Oct'05 - 73 messages
  • Singapore, Singapore
yes chewingyu, it sounds like the lift has a lock solenoid on the hydraulic control valve. It works with the operator presence system (the seat switch), when there is a presence in the seat it will unlock the system so it will work. More safety stuff the mfg thought was a good idea ;o). You could check the seat switch and see if there is a problem with it and/or the seatbelt (sometimes the seatbelt works with the seat switch in some models). If everything is ok there then it's more than likely the lock solenoid circuit.
  • Posted 23 Nov 2023 14:53
Thanks for your reply Swoop223. Apparently, according to our vendor, it cannot be lowered manually.
  • Posted 23 Nov 2023 14:46
  • By chewingyu
unfortunately this is a byproduct of engineering by making hydraulic function electric over hydraulic. In most if not all cases there is a manual ability to lower the forks by use of a manual valve on the control valve but it is up to the operator to know this and is most likely shown in the operators manual.
If the operators have not read the manual and 'know their lift' then these incidents occur.
In cases like these if there is any doubt then the lift should be left as is, moved out of the way, and the forks flagged so no one will accidentally run into them and service personnel called out to correct the issue.
And to be honest, if there is a load on the forks it should be left there because there is no safe way to remove the load if it is on the forks. The 2nd lift would have to go underneath the pallet which would allow the pallet to tilt over and slide off the forks. Pallets are made the way they are for that very reason, keeping the forks inside the enclosure of the pallet frame helps keep it from tipping over if the load becomes unstable.
Check the operator manual and i think you'll find a reference about manual lowering, if not then yes, there is a problem with mfg engineering not providing thorough enough information. You can submit the concern and suggestion with the mfg if you like but i'm sure their response is to call your service provider if you have any issues.
  • Posted 17 Nov 2023 00:57
Any response from anybody?
  • Posted 16 Nov 2023 17:02
  • By chewingyu
Upz post for response. Any manufacturers able to respond?
  • Posted 24 Mar 2023 17:43
  • By chewingyu
Sourdough bread contains Lactobacillus reuteri, a probiotic bacteria. During pregnancy and breastfeeding, these bacteria can travel from the mother's colon to her breast tissue and be passed to the infant through breast milk. It offers various health benefits, including potential protection against breast cancer.
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
