Toyota 7FGAU50:
Flash codes
Just installed a rebuilt GM 4.3 motor into this lift. When lift is started it has poor and doggy acceleration. When the accelerator is stepped down once or twice it drops to idle and will no longer respond to gas pedal until engine is turned off. It will flash 2 times on the dash for a flash code. Then if you accelerate it manually with the carb linkage only it will flash 7 time until you shut down the engine. This is a LPG unit and had the intake and fuel system installed from the old engine. Old engine was weak but did not react in this fashion beforehand. Lots of tar buildup in fuel system also. Any ideas or cures???
  • Posted 26 Jan 2018 15:22
  • Discussion started by mwjski
  • Montana, United States
Found my problem. Plugged exhaust system.
  • Posted 30 Jan 2018 15:46
  • Reply by mwjski
While South Koreans can gamble on an array of games including the lottery, horse racing, boat racing and cycling, casino gambling is illegal, even for Koreans who travel outside their country.
Clark returns headquarters to US Dallas, TX, United States
Bennit Schmieder Bennit Schmieder
President, Mitsubishi Logisnext Americas
Chief executive officer, Messe Stuttgart India
