Firt THREE LED light when i try to operate.
I need help with crown wav 50-84 giving first three LED light 421 and cant control the lifter from the front panel. It does have full battery. Thanks
  • Posted 9 Dec 2014 07:01
  • By muzza
  • joined 9 Dec'14 - 6 messages
  • Minnesota, United States
Muzamil
Thanks for your help. I did find the contactor and checked. thier funtioning ok powering off and on both the bottom one and the top one but one thing that is strange is that i cant controll the lift from the service pannel which i was suppose to if i cant do it from the platform. I did tried to override the hand sensors and that doesnt work eather. thanks. any more suggestion will help.
  • Posted 9 Dec 2014 08:36
  • By muzza
Muzamil
The contactor itself will be located under the floor board close to the teavel alarm....towards the front
  • Posted 9 Dec 2014 07:49
  • By kevin_t
Will be on the ground control panel.... BIG red button you push to disconnect the power in an emergency,might also be one on the platform control station also.......
  • Posted 9 Dec 2014 07:43
  • By kevin_t
Thanks I know the code but can't find where the ed-contact is can you help cause it not move or lift even when controlling from the service panel. Thanks
  • Posted 9 Dec 2014 07:25
  • By muzza
Muzamil
Static return to off during operation....
Possible causes:
Attempted to move vehicle with out hands and feet in place
Open ED-B contact or related circuit wiring
  • Posted 9 Dec 2014 07:07
  • By kevin_t
