fault codes
hello ,
fault codes FE77,FE42,FE43 on a FM12 serial number 611878000303
any still experts ,please help
peter
  • Posted 25 Sep 2017 19:43
  • By peterb
  • joined 23 Feb'16 - 125 messages
  • lancashire, United Kingdom
STILL FM -17, S/NO.611876000580, 3700HRS
The machine has the following error: FE 94, 0708 and 0101. kindly any help with interpretation and electrical schematic. omorrowca AT yahoo dot com
Will really appreciate.
Regards.
  • Posted 9 Feb 2021 00:51
  • Modified 12 Mar 2021 18:04 by poster
  • By Deto
  • joined 13 Feb'16 - 2 messages
  • Nairobi, Kenya
wongo22
i need help for error codes of still exv 12
  • Posted 6 Feb 2021 07:39
  • By Saeed_Khan
  • joined 6 Feb'21 - 4 messages
  • Pakistan
saeedkahn
Hi Peterb
FE42- SOK Faulty- The LAS Module does not receive the ok signal from the FPS within 3secs from after you have turned the key switch on. Check the FPS and the ribbon cable on connector X20
FE43- Battery Faulty - If the battery drops below 30volts this error will come on the Display
Are you sure the other error is FE77 as i have not seen this error before
Regards
  • Posted 28 Sep 2017 04:00
  • By Wongo22
  • joined 28 Sep'17 - 3 messages
  • hampshire, United Kingdom
Linde Material Handling
UN Forklift FD20-35FJM3
Big Joe PDR30-154
USD7,500
