fault code
Im hoping someone can help me out, I have this hyster unit that is showing fault code 32099, can someone tell me what that is? Thank you in advance.
  • Posted 31 Jan 2018 09:51
  • By Jay209
  • joined 31 Jan'18 - 1 message
DTC xx099 Internal - Fault
POSSIBLE CAUSE A. INTERNAL FAULT COMPONENT OPERATIONAL CHECK NOTE: Always check battery condition and state of charge before performing electrical troubleshooting. A faulty or low charged battery will cause electrical features to not operate as designed and give incorrect readings while performing electrical tests. PROCEDURE OR ACTION: 1. Conduct a visual inspection of all connectors/wiring associated with the fault code. Are any faults detected/observed? YES: Repair/replace connector or wiring associated with faults found. Refer to the appropriate Electrical System SRM. NO: Proceed to Step 2. 2. Re-key the vehicle. Is the code still present? YES: Proceed to Cause A. NO: Problem may be intermittent. CAUSE A - INTERNAL FAULT PROCEDURE OR ACTION: 1. Replace faulty controller. Make sure to indicate the DTC code(s) on the warranty claim to include an accurate problem description leading to controller replacement.
END POSSIBLE CAUSES
  • Posted 3 Feb 2018 19:16
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
You sure that is a fault code,dont find anything like that for the B60Z trucks....what is the complete model and serial number of the truck????
  • Posted 31 Jan 2018 12:31
  • By kevin_t
Hawker Powersource, Inc.
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
