Fault Code F3 - No Lift, No Drive.
CAT M100D (S/N 3CJ00723) 72V
Truck originally stopped working, with fault code F6 displayed.
Found a badly corroded pin connector on the logic board. Repaired that & the truck worked fine.
Came back to it the next day and fault code F3 on display.
Checked & cleaned all connections to logic board again, all seemed OK.
Checked transistors behind board. Drive pair measured OK.
One hydraulic transistor was open circuit and the second gave voltage & resistance readings completely dissimilar to the drive pair.
Ordered & fitted a pair of transistors to the hydraulic circuit but the F3 fault code remains and the truck is still without hydraulics or drive.
Any guidance good people?
Thank you.
  • Posted 22 Nov 2019 04:04
  • By TheDamo
  • joined 23 Feb'18 - 11 messages
  • Offaly, Ireland
Best regards,
Damien.
And might anyone have the test procedure & expected results for the head capacitors of the same truck?
Thanks again.
  • Posted 22 Nov 2019 05:10
  • Modified 22 Nov 2019 05:10 by poster
  • By TheDamo
  • Offaly, Ireland
Best regards,
Damien.
