Raymond EASI REACH:
FAULT CODE D2
PLEASE, I NEED YOUR HELP. WHAT IS MEAN THE CODE D2? THANKS FOR YOUR ANSWER.
  • Posted 21 Jun 2014 05:07
  • Discussion started by pedro_v
  • DF, Mexico
I think you mean 2D?
2D is field current senser out of range. Could be bad connection at power card, broken sensor...this is a plastic loop that is mounted to heat sink. power cable goes through it. Check for shorts to ground first. Remove heat sink and check for holes in insulator. A small hole causes short or arcing to frame.
  • Posted 21 Jun 2014 22:35
  • Reply by EasiTek
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
KION reports dip in Q1 revenue Frankfurt am Main, Germany
edition #1229 - 8 May 2025
