Fault code 523601
Yale GDP155VXNJJV126.
Fault code 523601?
Shuts off. Starter interlock. Then will start after about 20 minutes of not running. Something is getting hot. All fluids are good, filters clean, radiator clean. Please help.
Thanks.
  • Posted 3 Apr 2017 22:54
  • By Redbeard
  • joined 3 Apr'17 - 5 messages
Pin it to win it!
Could be a EGT sensor problem. If you have a temp gun you can scan the exhaust to see what the temp is running. I believe the temp cut off is 572 deg. F.
  • Posted 3 Apr 2017 23:36
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Morooka MFD20
VETTER Forks, Inc.
VETTER Forks, Inc.
