Hyster S50FT:
Fault Code 522761-6
Engine quits running or & shuts down hyd mini lever functions with code displayed.
Restart & run until it codes out,then shuts down engine.
  • Posted 5 May 2015 08:13
  • Discussion started by Horse
  • Wisconsin, United States
Jeff Bykowski
Well I noticed it shutting down when the seat was bouncing. Investigated & found mini lever wiring harness under suspension seat was routed improperly & caused pinch in harness which had worn through & shorted out. Problem fixed.
Thanxs for the help
  • Posted 8 May 2015 23:57
  • Reply by Horse
Jeff Bykowski
Its my own rental unit so nothing has been altered. I ll have to look @ harness for shorts to frame. Would you agree?
Switched batt current meaning. Anything powered from ignition side of ignition switch?? Which is relayed @ fuse board?
  • Posted 6 May 2015 00:13
  • Reply by Horse
check for shorts to ground, and also if someone has added _any_ device that was not 'factory" (backup alarm, strobe or lights included). 522761-6 is Switched Battery Current 2 (IGN 2) Current Too High OORL
  • Posted 5 May 2015 22:00
  • Reply by edward_t
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
Toyota 02-8FD25
JLG 1932R
JLG 1932R 2017
Flesherton, Ontario, Canada
