fault code -51 nothing works
dash display says capacitors voltage too low -any ideas??
  • Posted 30 Apr 2010 03:58
  • By troy_m
this unit quit while driving and the operator said he heard a loud humming noise like a pump motor. I checked and found a contactor welded together and it opened at my touch and the code -51 disappeared. I'll replace the contactor tip kit and see how it goes. Thanks for the suggestion.
troy
  • Posted 1 May 2010 07:55
  • By troy_m
check the current limiting resiter that bridges over the line contactor. it allows a small current into your controller to pre-charge the capacitors so they can self check before startup.
  • Posted 1 May 2010 04:32
  • By kevin_k
this might help E50XM2-33 #f108V232294
  • Posted 30 Apr 2010 03:59
  • By troy_m
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Terberg RT223
Terberg RT223
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
