Fault code 4123.11
Hello, first time posting here. I am a service tech with a Jungheinrich dealer. I have been dealing with an EFG220 that will intermittently throw code 4123.11. This code shows when the controller does not receive feedback from the park brake switches within 500 milliseconds. These two switches must work simultaneously. Originally the truck had a couple of other codes including the 4123.11 and it was determined that the controller was faulty. The controller was replaced and all codes except the 4123.11 went away. Park brake switches have also been replaced. The brake coil resistance is within spec and the switches are getting the proper voltage. The truck will work fine for awhile then throw the code.This happens when the truck is moving, or when key is cycled On. I've also had it show after a minute of turning the key to On without moving the truck. If the code only showed while traveling, I would say its a wire or connection issue. The fact that the code will will also show without the truck moving makes this issue more confusing. When the code shows, the way to clear it is to turn the key Off, hold park brake button, then turn key to On while still holding the park brake button. Has anyone dealt with this issue? Any help would be appreciated. Thanks!
  • Posted 4 Mar 2021 14:27
  • By Aaron_Anderson
  • joined 4 Mar'21 - 1 message
Hi can you show me the parking brake where exactly in jungherhaich efg320??
  • Posted 1 Dec 2022 19:38
  • By Akou_Davi
  • joined 1 Dec'22 - 3 messages
  • Algeria
Salutations
Change the keypad with the parking brake switch
  • Posted 2 Mar 2022 08:04
  • By SVAP
  • joined 2 Mar'22 - 7 messages
  • Slovenia
replace brake coils or be sure the metal plate behind the coil perfectly and have not damage. coils lose pulling force after start or drive
  • Posted 29 Oct 2021 00:39
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Hola como estas? Seguramente el freno se gastó. Esta falla la vi muchas veces pero de la forma 1123 en efg 220/320. Al principio solo podias iniciar el equipo sin falla tal como decis vos, apretando el freno desde el momento que giras la llave de encendido y hasta que termina el auto chequeo. Luego de un tiempo esto ya no funcionó mas y se debió desarmar frenos y cambiar discos.
Por el fabricante estos frenos son sin mantenimiento pero esto no es cierto porque hemos hecho varios cambios de estos discos de frenos en la empresa donde trabajé. Saludos y muchas suerte cualquier cosa me escribis.
Littoral Translation
Hi! How are you? Surely the brake was worn. I saw this flaw many times but in the form 1123 in efg 220/320. At first you could only start the equipment without failure as you decide, pressing the brake from the moment you turn the ignition key and until the self-check ends. After a while this no longer worked and had to disassemble brakes and change discs.
By the manufacturer these brakes are maintenance free but this is not true because we have made several changes to these brake discs in the company where I worked. Greetings and good luck, anything you write to me.
  • Posted 28 Oct 2021 12:53
  • Modified 28 Oct 2021 21:57 by administrator
  • By Ironman_93
  • joined 14 Dec'19 - 34 messages
  • Argentina
thefixerman.service@hotmail.com
Did you ever figure this machine out ???
  • Posted 27 Oct 2021 04:42
  • By Tony_rod
  • joined 27 Oct'21 - 1 message
Hotrod
Toyota 02-2TD20
Enforcer FLBAXT25
Combilift Ltd
Toyota 02-2TD20
Enforcer FLBAXT25
